Problem result sql query
Hello,
I'm new to the forum. I'm having a problem with the return of a SQL query. I'm looking to get the result of a SELECT query and reuse it in an SELECT query. I've tried a lot of different scripts but I can't do it. Here's my script.I'm looking for a way to convert my ESSAI3 result into a value that the INSERT query could include
I use MSSQL in serve :
CodeMat = system.tag.readBlocking(['[default]Cde_Matiere'])[0].value
essai =system.dataset.toDataSet(system.db.runPrepQuery("SELECT DISTINCT CodeStockage FROM tStockageInfo WHERE CodeMatiere = (?)", [CodeMat] ))
essai2 = system.dataset.toDataSet(system.db.runQuery("SELECT DISTINCT CodeStockage FROM tStockage WHERE CodeGroupe=1 AND NOT CodeStockage IN (Select CodeStockage FROM tStockageInfo) "))
essai3 = system.dataset.appendDataset(essai2,essai)
Here is my return script but the value is not good for ' essai3 ' :
system.db.runPrepQuery("SELECT DISTINCT LibelleL1 FROM tStockage WHERE CodeStockage IN ((?))", [essai3] )
Welcome to the forum, Theo.
See Wiki - how to post code on this forum. There's a pencil icon below the post so you can edit. You can also use Python's triple quotes to wrap your SQL for readability.
essai =system.dataset.toDataSet(system.db.runPrepQuery("""
    FROM tStockageInfo
    WHERE CodeMatiere = (?)""",
    [CodeMat])
essai2 = system.dataset.toDataSet(system.db.runQuery("""
    FROM tStockage
    WHERE CodeGroupe=1
        SELECT CodeStockage FROM tStockageInfo
essai3 = system.dataset.appendDataset(essai2, essai)
The code below won't work.
    FROM tStockage
    [essai3]
The prepared query can't take a dataset or even a list.
I think the best solution would be to convert the dataset to a comma separated string using a join function. Then pass that into the IN(_).
If this is all in one database, then you should be using a JOIN to express the chained condition.
I thank you for your response and I understood about the code publication. can you tell me the code to do the join? I can't find..
Thank you in advance
Replace all three queries with this:
SELECT DISTINCT s.LibelleL1
FROM tStockage s
LEFT JOIN tStockageInfo si
  ON s.CodeStockage = si.CodeStockage
WHERE si.CodeMatiere = ? OR (s.CodeGroupe = 1 AND si.CodeStockage IS NULL)
Pass just CodeMat as the one parameter.
OK, thanks a lot.
however if I want to retrieve a dataset from a SELECT query, how can I convert it so that in my INSERT query the language corresponds ?
I know of no way to do that with MS SQL Server. If you adopt a competent database technology, you can use SQL UNNEST() and similar technologies:
However, most people would combine the SELECT and the INSERT in a single statement, using this general syntax:
INSERT INTO someTable (someColumns....)
SELECT matchingColumns....
FROM ....
In the matchingColumns list of expressions, you might include expressions like:
    ? AS aColumnName
to inject desired constants into every new row.
ok, thank you for your valuable help. I'm going to try all of that.
Goodbye
