Welcome to the forum, Theo.
See Wiki - how to post code on this forum. There's a pencil icon below the post so you can edit. You can also use Python's triple quotes to wrap your SQL for readability.
CodeMat = system.tag.readBlocking(['[default]Cde_Matiere'])[0].value
essai =system.dataset.toDataSet(system.db.runPrepQuery("""
SELECT DISTINCT CodeStockage
FROM tStockageInfo
WHERE CodeMatiere = (?)""",
[CodeMat])
essai2 = system.dataset.toDataSet(system.db.runQuery("""
FROM tStockage
WHERE CodeGroupe=1
AND NOT CodeStockage IN (
SELECT CodeStockage FROM tStockageInfo
essai3 = system.dataset.appendDataset(essai2, essai)
The code below won't work.
SELECT DISTINCT LibelleL1
FROM tStockage
WHERE CodeStockage IN ((?))",
[essai3]
The prepared query can't take a dataset or even a list.
I think the best solution would be to convert the dataset to a comma separated string using a join function. Then pass that into the IN(_).
