Problem to create user at gateway using postgredSQl database
Hello I create PostgreSQl database connection
translate: error "scada-user relationship does not exist
When I try to create user , it doesn't work
PostgreSQl database
Can you tell me what I forgot to configure in PostgreSQl or on the gateway? Please
You need to use the adminstration account in PostgreSQL (not in Ignition), typically postgres, to create a login account that Ignition can use and assign its password. Typically, one would make that DB user the owner of the database hierarchy you will use with Ignition. At a minimum, that user must be granted the necessary access (again, done in PostgreSQL, not in Ignition).
On the Ignition side, you provide that user and password in the connection setup page so Ignition can use them to authenticate to PostgreSQL.
