Hi, I write you because i have a problem to open to an Ignition Designer project . The Ignition project was developed, in a server with Windows Server 2008 R2 (64 bits) and also runs the service there as the central server, and i want to open the project at the designer as a client from a pc with Windows 7 (64 bits). When I try to run the designer i log then it shows the project ia select the project and click on the open button then it starts to download and in seconds, it shows a windows error
and also the other errors that show in the window are
Error loading projects
Error listing projects
Error listing authentication profiles
Error listing database connections
Error listing SQLTag Providers
what can i do in this case? I looked that the project can only be open in a PC with XP (32 bits) operating system and also the system of the server (64 bits), but can not open in my PC with windows 7 (64 bits).
Please help me, because i need to work in the pc with windows 7 (64 Bits)
It sounds like it is a permissions issue. If you click on the details tab of the error messages it will give you more information. Once you click on the tab there is a link on the bottom of it to show more of the message. Click on this and post what the message is. This may also give you enough information to troubleshoot the issue yourself.
Hi
For message Error Loadin Project Details :
java.awt.IllegalComponentStateException: component must be showing on the screen to determine its location
Ignition v7.5.5 (b1255)
Java: Oracle Corporation 1.7.0_13
For the other messages :
Error listing projects, Error listing authentication profiles, Error listing database connections, Error listing SQLTag Provider Details :
GatewayException: The connection to the gateway is not available.
If the problem is a permissions issue, how can I solve this, because i can not open the project at the designer, but it lets me lunch (. jnlp) it in my pc? Please, i will appreciate your help. Other_errors.txt (1.93 KB) Error_loading_Project.txt (2.08 KB)
Hi and thanks, I tried clearing both Java cache and Ignition cache as you said me, but it still doesn’t work with Designer, it shows again the same errors, after seconds, as it happened before after it shows me the error message the window designer for opening the projects only shows me for make a new project as a default. and also is the error message window.
Hi, I tried with reinstallation of Java and I still have problems with runing the designer as a client user as I commented on this before.
Also I new thing that I saw is this:
At Section Java detection
say this: Ignition was unable to automatically detect what version of the Javatm Platform is installed on your computer. Please ensure that Java 6 or Java 7 is installed.
I solve my problem by myself, it was that karsperky antivirus doesn’t let run completely the designer , and also doesn’t let lunch faster the project, I get off the antivirus and the designer already run.
