Hello,
I am trying to upgrade the OEE demo included in version 7.6 to the new 7.7 version but I am getting an error:
What I did was:
- Installed Ignition 7.6+OEE module
- Configured OEE Module and Installed the demo
- Tested the demo (it worked ok)
- Upgraded to 7.7.1.
- Tested the demo again and found this problem:
The problem is with the Auto Schedule Gateway script, I’m getting this error on the log:
Traceback (most recent call last): File "<TimerScript:OEEDemo/Line Auto Scheduler @60,000ms >", line 29, in <module> File "<module:app.AutoSchedule>", line 14, in autoSchedule at com.sepasoft.production.server.opc.OPCProductionServer.read(OPCProductionServer.java:172) at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$ServerWrapper.read(OPCManagerImpl.java:707) at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl.read(OPCManagerImpl.java:433) at com.inductiveautomation.ignition.gateway.script.GatewayOPCUtilities.readValues(GatewayOPCUtilities.java:42) at com.inductiveautomation.ignition.gateway.script.GatewayOPCUtilities.readValuesImpl(GatewayOPCUtilities.java:37) at com.inductiveautomation.ignition.common.script.builtin.AbstractOPCUtilities.readValue(AbstractOPCUtilities.java:41) at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) java.lang.NullPointerException: java.lang.NullPointerException
I reviewed “Line Auto Schedule gateway script Line 29” and “app.AutoSchedule Line 14”, and I also checked the Machine paths and OPC paths and everything looks fine.
Is there something that I’m missing?
Thank you
