I have an Ignition server running on a linux box.
It is pointed at a Panel Edition running on a Windows 2003 server box.
The Panel Edition is being used as an I/O server.
The main Ignition server is pointed at the Panel Edition to get its I/O from the plcs.
Things were working fine with 7.2.7 on both machines.
The day 7.2.8 came out, I installed it on both machines.
The Panel Edition machine boots up fine and Ignition starts and begins polling the plcs.
At some point, java is consuming 99 percent cpu and it takes forever to just shut the machine down. This has happened multiple times.
The clients that are running off the main Ignition server are now showing problems with the items being pulled thru the Panel Edition.
As a work around, can I run 7.2.8 on the main and 7.2.7 on the Panel Edition.
The comms between the two are OPC UA.
Problems?
Dennis
