Problem with a storeProcedure
I exec a storeprocedure and try to get the value of the store but i can`t.
i checked the link system.db.createSProcCall - Ignition User Manual 8.1 - Ignition Documentation
but i only get None with the funtion “call.getResultSet()”
so i think the problem is the SP, i tried with return, with select also output int the store.
In all the situations if i exec the SP directly in SQL always give me a value,
what i made wrong?
Please share your stored procedure and the scripts you tried. We aren’t mind readers. /:
I think it’s in line 15 of the SP, that’s my hunch. That feels wrong to me
Except for Nick.
Eric, did you find a problem on line 15?
imagine if Nick was right xd
Sorry guys, but i really need to give to solution to the problem, so i made a select after exec the SP, but the SP its something like:
12
and tried to get the result with :
results = call.getResultSet()
table = event.source.parent.getComponent(table)
table.data = results
The final line in your SP is syntactically incorrect. Try:
Select @resultado AS out
