Problem with calling code in Ignition Designer Script Console
Hey everyone. I'm having some problem with calling a script in Ignition Designer in the Script Console tab. I am trying unsuccessfully to call the script which generates me the errors shown in the screenshot. The code I am trying to call is a very basic piece of code. When I try to query the database using SELECT all works as expected.
db = 'db_test'
query = '''INSERT INTO run(GoodCount) VALUES (?)'''
system.db.runPrepUpdate(query, [7], [db])
Do any of you have any ideas or suggestions for solving this problem?
The error is telling you you can't run that function when the designer is in read-only mode.
You're probably also going to run into issues supplying the database parameter as a list. It expects a string.
Welcome to the forum, kruta. Please see Wiki - how to post code on this forum. It won't make much difference to the short script you posted above but it will preserve leading whitespace / indentation which is essential for Python / Jython scripts. You can also post the error messages as preformatted text rather than an image. The text is searchable. The image is not without some OCR work.
Java Traceback:
File input, line 3, in module
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:268)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO run(GoodCount) VALUES (?), [7], ['db_test'], , false, false)
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:494)
at org.python.core.PyObject.__call__(PyObject.java:498)
at org.python.pycode._pyx8.f$0(<input>:3)
at org.python.pycode._pyx8.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at org.python.core.Py.exec(Py.java:1747)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO run(GoodCount) VALUES (?), [7], ['db_test'], , false, false)
... 26 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:393)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:293)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:261)
... 24 more
I actually find it easier to read the error trace as a screenshot... Especially on mobile
