TagVal = system.tag.read("KTS_SQL/K-18/Tоп_К18")[/quote]I get a same error.
I try this:TagVal = system.tag.read("KTS_SQL/K-18/Tоп_К18")and thisTagVal = system.tag.read('KTS_SQL/K-18/Tоп_К18')andTagVal = system.tag.read(u'KTS_SQL/K-18/Tоп_К18')All result the same error.
I was update Ignition to version 7.5.4 and try execute samples code - changed nothing.
I was sure that in names of tags there can be unicode charakters. What’s wrong?
[quote=“michael.stofan”]system.tag.read() only takes in a string as an argument, so in this case you won’t want to have anything in there that is outside of the quotes.[/quote]Char ‘u’ before quotes is common unicode prefix in Ignition. Isn’t it?
