Problem with Designer Launcher on Xubuntu 22.04
Hi! I currently am trying to install ignition on a fresh install of Xubuntu through VMware. Currently, the designer launcher silently fails every time I go to execute it. When I look at the logs this is what I see:
INFO  [CompositeClassRejectListFilter] [2024/10/17 10:51:16]: Initialization performed successfully
INFO  [CompositeClassRejectListFilter] [2024/10/17 10:51:16]: JVM-wide ObjectInputFilter set up successfully
INFO  [CompositeClassRejectListFilter] [2024/10/17 10:51:16]: Platform serialFilter has 88 pattern(s)
INFO  [DesignerLauncher              ] [2024/10/17 10:51:16]: Set initial logging level to INFO
ERROR [RuntimeException              ] [2024/10/17 10:51:16]: Uncaught exception in thread: main
java.lang.RuntimeException: java.lang.UnsatisfiedLinkError: no glassgtk3 in java.library.path: /usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
	at com.sun.javafx.tk.quantum.QuantumToolkit.startup(QuantumToolkit.java:301)
	at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:293)
	at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:163)
	at com.sun.javafx.application.LauncherImpl.startToolkit(LauncherImpl.java:659)
	at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:679)
	at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:196)
	at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: java.lang.UnsatisfiedLinkError: no glassgtk3 in java.library.path: /usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
	at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2434)
	at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:818)
	at java.base/java.lang.System.loadLibrary(System.java:1993)
	at com.sun.glass.utils.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:166)
	at com.sun.glass.utils.NativeLibLoader.loadLibrary(NativeLibLoader.java:54)
	at com.sun.glass.ui.gtk.GtkApplication.lambda$new$6(GtkApplication.java:195)
	at java.base/java.security.AccessController.doPrivileged(AccessController.java:318)
	at com.sun.glass.ui.gtk.GtkApplication.<init>(GtkApplication.java:179)
	at com.sun.glass.ui.gtk.GtkPlatformFactory.createApplication(GtkPlatformFactory.java:41)
	at com.sun.glass.ui.Application.run(Application.java:146)
	at com.sun.javafx.tk.quantum.QuantumToolkit.startup(QuantumToolkit.java:291)
I thought the problem was just that I didn't have gtk3 installed, so against my better judgement, I even ran
sudo apt install libgtk-3-dev
with no change. Has anyone ran into this issue before? Any help would be greatly appreciated!
I typically stick with Kubuntu or Ubuntu (or other variations using KDE or GNOME like PopOS). I'm wondering if XFCE is too lightweight to support Ignition.
Maybe that is the issue? I have installed Ignition on both Arch and Debian based distros before with no issue ( EndeavourOS with KDE and Linux Mint Cinnamon). This is the first time I've tried to install it in a XFCE desktop environment and this is the only time I have ever had difficulty with the installation.
