I’m experiencing a problem. I have a control dialog box much like your System Control example that is passed a number of parameters when it is opened. Whenever I save in the Designer or run this for the first time as a project, I receive a number of java Null pointer errors for various components. It appears to me they are uninitialized somehow. When I look at the values in Designer, they are 0 or 1.
Is there a way to work around this problem?
Thanks in advance.
Error report:
java.lang.NullPointerException
at com.inductiveautomation.factorypmi.application.binding.expression.DefaultFunctionFactory$IfFunction.execute(DefaultFunctionFactory.java:864)
at com.inductiveautomation.factorypmi.application.binding.expression.FunctionExpression.execute(FunctionExpression.java:46)
at com.inductiveautomation.factorypmi.application.binding.expression.DefaultFunctionFactory$IfFunction.execute(DefaultFunctionFactory.java:875)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.connect(ExpressionPropertyAdapter.java:79)
at com.inductiveautomation.factorypmi.application.FHMIWindow.connectAdapters(FHMIWindow.java:215)
at com.inductiveautomation.factorypmi.application.FHMIApp.openWindow(FHMIApp.java:731)
at com.inductiveautomation.factorypmi.application.FHMIApp.openWindow(FHMIApp.java:688)
at com.inductiveautomation.factorypmi.designer.model.ObjectHolder.openWindow(ObjectHolder.java:1997)
at com.inductiveautomation.factorypmi.designer.navtree.ProjectBrowserPanel.mousePressed(ProjectBrowserPanel.java:387)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
