I have a strange issue with an OPC-UA connection. In the gateway in status is showing an OPC-UA connection that I cannot see in gateway config. It is marked as FAULTED and it shows the exception:
java.lang.Exception: Error creating OPC server “SIMATIC.S7-1500.OPC-UAServer:PLC_1” of type “com.inductiveautomation.OpcUaServerType”
- at com.inductiveautomation.ignition.gateway.opc.OpcConnectionManagerImpl.newOpcConnection(OpcConnectionManagerImpl.java:166)*
- at com.inductiveautomation.ignition.gateway.opc.OpcConnectionManagerImpl.registerConnectionType(OpcConnectionManagerImpl.java:243)*
- at com.inductiveautomation.ignition.gateway.opcua.OpcUaModule.startup(OpcUaModule.kt:304)*
- at com.inductiveautomation.ignition.gateway.opcua.OpcUaModuleHook.startup(OpcUaModuleHook.kt)*
- at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2433)*
- at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startup(ModuleManagerImpl.java:411)*
- at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1146)*
- at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:293)*
- at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:710)*
- at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:644)*
- at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)*
- at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)*
- at java.base/java.util.concurrent.FutureTask.run(Unknown Source)*
- at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)*
- at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)*
- at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)*
- at java.base/java.lang.Thread.run(Unknown Source)*
Caused by: java.lang.IllegalStateException: context.persistenceInter…erSettings) -
) must not be null* - at com.inductiveautomation.ignition.gateway.opcua.client.connection.OpcUaConnectionType.createNewOpcConnection(OpcUaConnectionType.kt:43)*
- at com.inductiveautomation.ignition.gateway.opc.OpcConnectionManagerImpl.newOpcConnection(OpcConnectionManagerImpl.java:161)*
- … 16 more*
8.0.17 (b2020111211)
Azul Systems, Inc. 11.0.7
It is very annoying because I have a table where I show all OPC-UA connections (despite they are FAULTED or CONNECTED) and this one is appearing there and no one know what it is. The table uses the script system.opc.getServers() to be filled.
Does someone know what can be the reason of this connection?
