Problem with reading added files from MicroLogix 1400
I’ve got a MicroLogix 1400 that was working fine and I was able to see all the data I needed in Ignition. I recently added a float file and Ignition will not read it. Has anyone else had similar problems? What was done to fix it?
Ignition: 7.9.1
MicroLogix 1400
There are some Message and Routing files that Ignition doesn’t see, then the new float file is after them. Would that make a difference?
I have restarted Ignition.
Did not try power cycling the PLC. Will do that next time I am on site.
