I haven’t yet upgraded to Maven, but I’m updating a module from 7.7.x to run in a 7.8.1 system. I built it with Ant and updated the linked libraries.
The module works fine in my developer-enabled server, but I can’t install it in the production server.
I created a self-signed certificate with KeyStore, just a simple key-pair, and exported the certificate chain.
Signed it with the module signer.
But the installation throws a “signature not present” exception:
com.inductiveautomation.ignition.gateway.modules.ModuleVerificationException: Module signature not present.
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.verifyModuleSignatures(ModuleManagerImpl.java:1685)
I unzipped the .modl and the signature is there…
I have tried a few approaches, like creating another key pair signed by the first one, so a 2-length certificate chain, but with the same result.
Any clues as to what the problem is? the signed module is attached…
Correct, self-signed modules only work in the latest versions of 7.7, 7.8, 7.9. We can’t support the legacy signing any more.
I think there’s some process through which we can make a one time exception and manually sign a module you send us if you’re in a pinch here, but generally you’re expected to upgrade off 7.8.1 or whatever non-up-to-date version if you’re relying on custom developed or 3rd party modules.
It’s not the most graceful transition ever but we didn’t have any other options.
