I have a popup window that I am building. It has a custom property of a UDT type that will get passed to it when the popup is opened from another window.
On the popup screen is a button that I would like to use to set the value of a tag in the UDT. The tag name has some spaces in it, and this is causing an issue.
The property path is: event.source.parent.FurnaceUDT.Programmer.Programmer Mode Status
Is there a way I can escape the spaces in the tag name? Or am I stuck with renaming the tag?
Thanks,
Brian
