I’m currently updating an ignition system that was working in conjunction with RS FactoryTalk Transaction Mgr, basically relocating all the transactions to Ignition. I created a stored procedure group for an existing procedure that FTM is using. I can select it from the dropdown in the configuration, but when it is triggered, it errors out saying it can’t find the stored procedure.
I am using the same group at another location w/o a problem. Any ideas?
Did you try creating a copy of the stored procedure in the db and using that?
That worked for some reason, thanks!
