Hello,
I am using Ignition Version: 7.6.3-rc2 (b2448). I am trying to create an SQL Tag Change Event script in Client Event Scripts. I followed the user manual and tried running the following script as shown in the manual. This particular script works.
“Received tag change event for %s” % event.tagPath
value = newValue.value
quality = newValue.quality
timestamp = newValue.timestamp
print “value=%s, quality=%s, timestamp=%s” %(value, quality, timestamp)
However, now I am trying to improvise on this example for my purpose which is where I am running into an error. I want to store the tagPath name as a string and use it later on. So, I tried to use the following
tagname = str(event.tagPath) Or
tagname = event.tagPath
However, in either case, I get an error in the Diagnostics > Console saying
AttributeError: ‘com.inductiveautomation.ignition.common.sqltags.mo’ object has no attribute ‘tagpath’
Can someone please let me know what is the correct way to store the event.tagPath name in a variable?
Thanks,
Shreyas
