Below is the log from the point where it tries to restart after upgrading.
What do you see wrong?
Dennis
STATUS | wrapper | 2011/11/29 10:02:08 | <-- Wrapper Stopped
WARN | wrapper | 2011/11/29 10:02:08 | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | 2011/11/29 10:02:08 | /usr/local/bin/ignition/wrapper-license.conf
WARN | wrapper | 2011/11/29 10:02:08 | trying the system encoding.
STATUS | wrapper | 2011/11/29 10:02:08 | --> Wrapper Started as Daemon
STATUS | wrapper | 2011/11/29 10:02:08 | Java Service Wrapper Standard Edition 64-bit 3.5.4
STATUS | wrapper | 2011/11/29 10:02:08 | Copyright © 1999-2010 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2011/11/29 10:02:08 | wrapper.tanukisoftware.com
STATUS | wrapper | 2011/11/29 10:02:08 | Licensed to Inductive Automation for Ignition Gateway
STATUS | wrapper | 2011/11/29 10:02:09 | Launching a JVM…
INFO | jvm 1 | 2011/11/29 10:02:09 | Please use CMSClassUnloadingEnabled in place of CMSPermGenSweepingEnabled in the future
INFO | jvm 1 | 2011/11/29 10:02:09 | WrapperManager: Initializing…
INFO | jvm 1 | 2011/11/29 10:02:09 | Nov 29, 2011 10:02:09 AM org.apache.catalina.startup.Embedded start
INFO | jvm 1 | 2011/11/29 10:02:09 | INFO: Starting tomcat server
INFO | jvm 1 | 2011/11/29 10:02:10 | Nov 29, 2011 10:02:09 AM org.apache.catalina.core.StandardEngine start
INFO | jvm 1 | 2011/11/29 10:02:10 | INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
INFO | jvm 1 | 2011/11/29 10:02:10 | Nov 29, 2011 10:02:09 AM org.apache.catalina.startup.DigesterFactory register
INFO | jvm 1 | 2011/11/29 10:02:10 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_0.xsd
INFO | jvm 1 | 2011/11/29 10:02:10 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_1.xsd
INFO | jvm 1 | 2011/11/29 10:02:10 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_1.dtd
INFO | jvm 1 | 2011/11/29 10:02:10 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_2.dtd
INFO | jvm 1 | 2011/11/29 10:02:10 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_0.xsd
INFO | jvm 1 | 2011/11/29 10:02:10 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_1.xsd
INFO | jvm 1 | 2011/11/29 10:02:10 | INFO [SRClassLoader ] [10:02:10,567]: SRClassLoader init
INFO | jvm 1 | 2011/11/29 10:02:10 | INFO [SRContext ] [10:02:10,977]: Ignition["/main", state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2011/11/29 10:02:11 | INFO [SRContext ] [10:02:10,991]: Starting Ignition 7.3.0 (b460)
INFO | jvm 1 | 2011/11/29 10:02:11 | INFO [SRContext ] [10:02:10,993]: Reloading JDBC classloader.
INFO | jvm 1 | 2011/11/29 10:02:11 | INFO [SecureRandomProvider ] [10:02:11,084]: Creating SecureRandom object…
INFO | jvm 1 | 2011/11/29 10:02:11 | INFO [SecureRandomProvider ] [10:02:11,084]: Generating seed…
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [SecureRandomProvider ] [10:02:16,089]: … Seed Created.
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [SecureRandomProvider ] [10:02:16,090]: … SecureRandom Created.
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [StateMonitoring ] [10:02:16,276]: The cluster node state has changed. Current state: [RedundancyState[role=Independent, activity level=Active, project state=Good, history level=Full]
INFO | jvm 1 | 2011/11/29 10:02:16 | WARN [ModuleManager ] [10:02:16,304]: Could not read license from HASP key.
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [Application ] [10:02:16,399]: [SRContext] init: Wicket core library initializer
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,401]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,402]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,403]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,404]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,405]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,405]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,406]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,406]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,425]: registered listener interface [RequestListenerInterface name=IActivePageBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [RequestListenerInterface ] [10:02:16,426]: registered listener interface [RequestListenerInterface name=IActivePageBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [Application ] [10:02:16,426]: [SRContext] init: Wicket extensions initializer
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [WebApplication ] [10:02:16,445]: [SRContext] Started Wicket version 1.4.5 in deployment mode
INFO | jvm 1 | 2011/11/29 10:02:16 | Nov 29, 2011 10:02:16 AM org.apache.coyote.http11.Http11Protocol init
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO: Initializing Coyote HTTP/1.1 on http-8088
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [SystemInfo ] [10:02:16,516]: os.name=“linux”, os.arch=“amd64”.
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [SystemInfo ] [10:02:16,516]: Validating native library “ignition-x64”…
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [SystemInfo ] [10:02:16,522]: Validated ignition-x64 (libignition-x64.so)
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO [SystemInfo ] [10:02:16,523]: Loading native library “ignition-x64”…
INFO | jvm 1 | 2011/11/29 10:02:16 | Nov 29, 2011 10:02:16 AM org.apache.coyote.http11.Http11Protocol start
INFO | jvm 1 | 2011/11/29 10:02:16 | INFO: Starting Coyote HTTP/1.1 on http-8088
INFO | jvm 1 | 2011/11/29 10:02:17 | Nov 29, 2011 10:02:17 AM org.apache.coyote.http11.Http11Protocol init
INFO | jvm 1 | 2011/11/29 10:02:17 | INFO: Initializing Coyote HTTP/1.1 on http-8043
INFO | jvm 1 | 2011/11/29 10:02:17 | Nov 29, 2011 10:02:17 AM org.apache.coyote.http11.Http11Protocol start
INFO | jvm 1 | 2011/11/29 10:02:17 | INFO: Starting Coyote HTTP/1.1 on http-8043
INFO | jvm 1 | 2011/11/29 10:02:21 | INFO [LocalDBManagerImpl ] [10:02:21,602]: Starting up…
INFO | jvm 1 | 2011/11/29 10:02:21 | INFO [LocalDBManagerImpl ] [10:02:21,607]: Looking for existing internal database “settings”…
INFO | jvm 1 | 2011/11/29 10:02:22 | INFO [ENGINE ] [10:02:22,139]: open start
INFO | jvm 1 | 2011/11/29 10:02:22 | INFO [ENGINE ] [10:02:22,148]: open end
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [ENGINE ] [10:02:22,955]: dataFileCache commit start
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [LocalDBManagerImpl ] [10:02:22,976]: … found existing.
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [ENGINE ] [10:02:23,313]: Checkpoint start
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [ENGINE ] [10:02:23,388]: dataFileCache commit start
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [ENGINE ] [10:02:23,400]: Checkpoint end
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [LocalDBManagerImpl ] [10:02:23,402]: internal database “settings” started up successfully.
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [LocalDBManagerImpl ] [10:02:23,403]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database “settings”]
INFO | jvm 1 | 2011/11/29 10:02:23 | INFO [Notification ] [10:02:23,480]: Alert notification system created.
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,528]: Looking for existing store and forward datacache “igndb”…
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,587]: open start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,590]: open end
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,601]: dataFileCache commit start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,616]: … found existing.
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,618]: Checkpoint start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,625]: dataFileCache commit start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,636]: Checkpoint end
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,637]: store and forward datacache “igndb” started up successfully.
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,637]: Registering autobackup task [owner=Internal DB Autobackup, name=store and forward datacache “igndb”]
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [igndb ] [10:02:24,789]: History sink started successfully.
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,791]: Looking for existing store and forward datacache “l504_Oven_Alarm_DB”…
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,815]: open start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,822]: open end
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,829]: dataFileCache commit start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,840]: … found existing.
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,841]: Checkpoint start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,874]: dataFileCache commit start
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [ENGINE ] [10:02:24,883]: Checkpoint end
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,884]: store and forward datacache “l504_Oven_Alarm_DB” started up successfully.
INFO | jvm 1 | 2011/11/29 10:02:24 | INFO [HSQLDataStore ] [10:02:24,884]: Registering autobackup task [owner=Internal DB Autobackup, name=store and forward datacache “l504_Oven_Alarm_DB”]
INFO | jvm 1 | 2011/11/29 10:02:25 | INFO [l504_Oven_Alarm_DB ] [10:02:25,129]: History sink started successfully.
INFO | jvm 1 | 2011/11/29 10:02:25 | INFO [ModuleManager ] [10:02:25,382]: Trial time reset. Time remaining = 5009. Notify modules = false.
INFO | jvm 1 | 2011/11/29 10:02:25 | INFO [ModuleManager ] [10:02:25,384]: Setting up modules
INFO | jvm 1 | 2011/11/29 10:02:25 | ERROR [SRContext ] [10:02:25,587]: Error during context startup.
INFO | jvm 1 | 2011/11/29 10:02:25 | simpleorm.utils.SException$Jdbc: Getting Field 4 from simpleorm.sessionjdbc.SSessionJdbcHelper@748ae431
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.sessionjdbc.SSessionJdbcHelper.retrieveRecord(SSessionJdbcHelper.java:464)
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.sessionjdbc.SQueryExecute.findOrCreateFromResultSet(SQueryExecute.java:194)
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.sessionjdbc.SQueryExecute.executeQuery(SQueryExecute.java:68)
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.sessionjdbc.SSessionJdbc.queryNoFlush(SSessionJdbc.java:489)
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.sessionjdbc.SSessionJdbc.query(SSessionJdbc.java:498)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.query(PersistenceInterfaceImpl.java:145)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.addAll(DatasourceManagerImpl.java:288)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.startup(DatasourceManagerImpl.java:576)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:887)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:182)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:679)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.SRContext.access$200(SRContext.java:185)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:515)
INFO | jvm 1 | 2011/11/29 10:02:25 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | Caused by: java.lang.IllegalArgumentException: No enum const class com.inductiveautomation.ignition.common.datasource.DatabaseVendor.FIREBIRD
INFO | jvm 1 | 2011/11/29 10:02:25 | at java.lang.Enum.valueOf(Unknown Source)
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.dataset.SFieldEnum.convertToDataSetFieldType(SFieldEnum.java:52)
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.dataset.SFieldEnum.queryFieldValue(SFieldEnum.java:42)
INFO | jvm 1 | 2011/11/29 10:02:25 | at simpleorm.sessionjdbc.SSessionJdbcHelper.retrieveRecord(SSessionJdbcHelper.java:461)
INFO | jvm 1 | 2011/11/29 10:02:25 | … 21 more
INFO | jvm 1 | 2011/11/29 10:02:25 | INFO [SRContext ] [10:02:25,591]: Ignition["/main", state=STARTING] ContextState = FAULTED
