Hello,
I install Ignition on a server that already have winCC and after that win cc goes down all the time. Apparently the problem is with the computer browser service…
Some one had the same problem ?
Hello,
There’s nothing I can think of that gets installed that should affect WinCC. The only install that could affect both sides is the OPC Core Components install, but we don’t include that by default.
Is it possible that WinCC is using a TCP port that Ignition is using or something? I suspect it must be something like this, instead of a direct software conflict.
Also, did WinCC stop working right after install, or after you tried to make a connection to it in Ignition?
Regards,
