I have a problem with the historization of data into a PostgreSQL database. I have a PLC that shares data with Ignition via OPC. In Ignition I have a reference to this tag using tag reference and I have defined a history for this tag.
The data goes to the database is configured as a record using the group tag. At some point, the data stops updating, that is, in the OPC the data changes so the reference tag, which should write the data to the database because I defined a history on it, also changes. I keep getting the same value according to the defined time in the group tag.
I created a new history tag and the data is not saved on this history provider from this particular tag provider. From other providers the tags save. I have already tried restarting the whole Ignition system and the database but the problem is not solved. I'm afraid something has thrown off internally and I don't know how to diagnose or fix it. Sometimes I have been able to solve these problems with a reboot but this time it doesn't help....
Does anyone have any ideas I am grateful for any suggestions?
Greetings
Michał
