Our IT has updated the ignition version from 8.1.19 to 8.1.45. After the update I found two problems:
All tag values disappeared in tag browser.
All Python Scripts indents displayed abnormal
Does anyone know the reason? Is it a bug for the version update?
Thank you! Jordan.
The tag value comes back after I clean the cache and reload the project. problem 1 solved.
for the problem2, I found the tab lines is showed every 4 spaces, but the actual tab key is not 4 spaces, the tab key is 7 spaces. Are there any method to specify the qty of spaces for the tab key?
No2 also shows up if your OS display settings have a zoom factor of anything with a decimal eg the "recommended" setting on some monitors is 125% (1.25) which will screw with your designer
