OPC Server is Standard Automation Universal Server. I can connect to it no problem using matrikon opc explorer. I go thru the setup and everything seems to go fine until I try and add a tag. when I try and browse down in the folders it gives me this error
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 500: COM object method returns error code: 0x80004005; E_FAIL (Unspecified error)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:236)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:211)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:201)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:587)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCFolderNode.loadChildren(OPCFolderNode.java:48)
at com.inductiveautomation.ignition.client.util.gui.tree.AbstractAsynchronousTreeNode$Loader.run(AbstractAsynchronousTreeNode.java:65)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x80004005; E_FAIL (Unspecified error)
at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:744)
at com.jniwrapper.win32.com.impl.IUnknownImpl.invokeStandardVirtualMethod(SourceFile:723)
at com.inductiveautomation.opccom.interop.opcda.impl.IOPCItemPropertiesImpl.getItemProperties(IOPCItemPropertiesImpl.java:79)
at com.inductiveautomation.opccom.wrapper.browsing.BrowserDA2$BrowseJob2.getItemDataType(BrowserDA2.java:211)
at com.inductiveautomation.opccom.wrapper.browsing.BrowserDA2$BrowseJob2.browseItems(BrowserDA2.java:189)
at com.inductiveautomation.opccom.wrapper.browsing.BrowserDA2$BrowseJob2.internalRun(BrowserDA2.java:117)
at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:45)
at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:566)
at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:508)
