Ignition 8.1.7
I’m having trouble getting a valid quality code from tags that have bad quality. I made a script to browse through a tag folder/provider and print any tag path that isn’t good, excluding any that are disabled (quality code 515).
When testing this, I realized my code returns 192 for good tags (expected), but a wild negative when quality is bad (e.g. -2147483124). Code below.
I feel like I’m missing something, but if so, why I can read good quality correctly?
def get_bad_tags(path):
results = system.tag.browse(path, {})
for result in results.getResults():
# skip UDT definitions
if result['name'] == '_Types_':
continue
# recurse through folders/UDTs
if result['hasChildren'] == True:
get_bad_tags(result['fullPath'].toString())
continue
# print tag paths that aren't good, excluding disabled tags
if result['tagType'].toString() == 'AtomicTag':
print(str(result['value'].quality.getCode()))
if result['value'].quality.isNotGood() and result['value'].quality.getCode() != 515:
print(result['fullPath'].toString())
For reference, Bad 2 is Bad_OutOfRange (524)
Try using only the lower 16 bits of the code you get back, i.e. getCode() & 0xFFFF
Thanks, that worked! I see now it’s documented here in the Javadocs, for anyone else that’s curious.
Looks like I also could have done result['value'].quality.getName() == 'Bad_Disabled', which is definitely more readable.
To close the loop, this is my updated script:
continue
continue
if (
(result['value'].quality.getCode() & 0xFFFF) != 515 # disabled
Another option would be to compare against one of the static final fields in QualityCode:
from com.inductiveautomation.ignition.common.model.values import QualityCode
if (
result['value'].quality.isNot(QualityCode.Bad_Disabled)
