I posted this under "FactoryPMI Problems but then realized it might be better suited under this heading.
I am having a problem with migrating all my forms and SQL queries from MySQL to MSSQL. The code for the script that is excuted whenever I want to try and open a CSV file is in the attached file. I do not think my syntax is wrong between MySQL and MSSQL but maybe it is because the script works perfectly when pointed at the MySQL database. Thanks for your help!
- Caleb
Script.txt (724 Bytes)
