Problems scripting a button to save a file
I am having issues saving a file via pressing a button. My script is below. I am not receiving an error in my logs, but I don’t see the file in the path where it’s supposed to be.
In the path, try adding another backslash anytime you have a backslash present.
I just tried this, but I still don’t see the file.
Does the account being used by the Ignition service have permission to write to this directory?
I’m not sure, how would I check this?
The path has to be accessible to the Gateway(Server)
Setting Keys: "path", "fileName" and "format".
Note: Since the script is sent to the gateway for execution, path and fileName must be relative to the gateway.
https://docs.inductiveautomation.com/display/DOC79/system.report.executeAndDistribute
