Good evening, I need support because I did a proyect in my pc and when I tried to pass the back up to server, I cant restore… Can you help me?
thanks
thanks
Can you find the error you got when the restore failed? The most common cause for a restore to fail is if you create a backup on a newer version (ie7.3.3) than what you restored it to (ie 7.2.9).
Thanks for the support.
but I have another question, does not affect licensing, upgrading 7.2.5 to 7.2.8 ignition?
I can do to not affect licenses?
thanks
Upgrading from 7.2.5 to 7.2.8 will not affect licensing.
How I can upgrade from 7.2.5 to 7.2.8 ignition?
On the server I have no internet access.
only install the update file and that is?
Yes, just run the installer/upgrader and that is it.
