I highlight a Numeric Text Field and Select the All Filter for Properties on the right.
Then I go down to the Decimal Property and enter something like #,##0.00
When I save the project and come back, the formatting goes back to the default.
In the meantime…
I created a String type Memory Tag and put the value of #,##0.00 into it. Then I bound the Numeric Text Field’s Decimal Format property to it and it works. I couldn’t find anything in the help to lead me to this, I just played around until I found this particular solution.
…And Now…
I just added a new Numeric Text Filed and I can enter the format in the property window and it stays
The bold text indicates that the value is bound to something. This means that a manually entered value will get overwritten automatically. I’m guessing that was configured automatically by dragging a SQLTag to a window to create an object. It might be bound to the tag metadata itself, so changing the value of that tag property may do it. In any case, you can easily modify/remove that binding by clicking on the database/lock looking icon to the right.
