Hello,
In the project I’m working we have a lot of product codes. Unfortunately when we entered the product codes we didn’t follow a particular order , so now pick a code from the Drop-Down list became too tedious.
There is a way to sort the product code Drop-Down list?
Also do you now if it’s possible to apply filters, so that the Drop-Down will present just some products?
I guess I have found a solution myself, and maybe it can help someone else
So what I did is to use the standard drop down component, the Production Line Selector, a text for the filter and a check box to enable or disable the filter.
The drop down dataset is defined using system.db.runQuery which sorts and filters the data; the system.db.runQuery returns a dataset.
The query get generated every time the operator change the Production Line selection accordingly with the filter and the checkbox status.
I attached a picture and a text with the scripting if someone has the same issue
