Productivity 2000 PLCs
Copied from a forum for Automation Direct:
The Productivity Series CPUs support Class 1 Connections (I/O Messaging), Class 3 Connections (Connected Explicit Messaging), and Unconnected Explicit Messaging. The CPUs can act as I/O Scanners, I/O Adapters, Explicit Messaging Clients, and Explicit Messaging Servers. This information can be found in the Help Topics within the software.
The Micro800 series does support CIP Symbolic Messaging, which is not currently supported by the P-Series. This messaging targets the actual string of ASCII characters that define the tag (e.g. “Tag01”), rather than an Instance of an Assembly object (or other Class, Instance, and Attribute).
I hope this helps. From what i see so far I don’t think you will be able to browse this like you can an AllenBradly. This is based on what I highlighted in bold.
