Over the weekend, my project has decided it doesn’t like me, I guess.fails to run. Friday everything worked. Today, I can log into the Gateway. I can log into the designer. When trying ro run a project, I can not log into it. The above error occurred. Looking at the log, this error happens a lot.
Ignition 8.0.13
java.lang.NullPointerException: null
at com.inductiveautomation.ignition.gateway.authentication.impl.DatabaseAutomaticUserSource.getUsers(DatabaseAutomaticUserSource.java:366)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.doGetUsers(UserSourceWrapper.java:179)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.updateCache(UserSourceWrapper.java:206)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceManagerImpl$UpdateCacheTask.run(UserSourceManagerImpl.java:401)
Any suggestions on where to look to fixe this?
