Progress bar in Perspective table
Is there any way to apply this method in a Perspective table?
You make a separate view that contains a progress bar component, then on your table, set the render option to view with a path
You can also do this directly in the table
  • Add the list of columns under the table props and assign the columns[x].field to match the column names
  • Set columns[x].render to "number", and columns[x].number to "progress"
  • Adjust the min/max values and its appearance under columns[x].progressBar
@Cheryl_Ramey , when an IA staff member splits one of your questions into a new topic, it is not appropriate to repost the Q in the original topic again.
Apologies I didnt see that it had split I thought I had accidentally posted in the wrong thread.
