Hi all,
I need to use an embedded Progress Bar (only available in Table component) but also need the Cell Spanning feature (only available in Power Table component)… It seems mutually exclusive.
So, is there any way to do Cell Spanning in a regular Table OR an embedded Progress Bar in the Power Table (OR some other clever alternative)?
Carl,
Thanks for the quick reply… It works great! Now my next (final?) question is how to change the colors of the foreground (the bar itself) and background (the field that the bar sits against)? For example, if I want a red bar against a white background, how do I code that?
*Note (no action needed - just a fun fact…):
I noticed that the configureCell extension function seems to be hierarchical - if I put the progress bar snippet you gave me AFTER the included script for alternating row color, the bars would not appear. But if I put the snippet BEFORE the other script, it would work fine.
jpark,
When I add those lines to my code, the progress bars disappear.
Prior to me adding the lines, I had:
if colName=="Order":
from javax.swing import JProgressBar
bar = JProgressBar(0, 100)
bar.setValue(value)
return {'renderer': bar}
And I saw gray progress bars.
Afterwards I had:
bar.setValue(value)
bar.background = Color.WHITE
bar.foreground = Color.RED
And the bars disappeared and were replaced with their values.
I am trying to build off these examples and utilize the indeterminate property to just animate the progress bar that has unknown steps to complete. I have this code in configureCell, but it only shows about 20% of the bar, stuck to the left. It’s as if the animation piece isn’t executing when it is embedded in the power table.
if colName == "Status":
from java.awt import Color
bar = JProgressBar(0,100)
bar.background = self.parent.parent.LightColor
bar.foreground = self.parent.parent.DarkColor
bar.setIndeterminate(value)
My status column is a boolean. Thoughts as to why it’s not animated like a progress bar component is with the indeterminate value set?
