Progress Bar Right to Left instead of Left to Right
Hello,
I am using Ignition Perspective and I needed some assistance changing the progress bar to left to right. What properties should I change?
It is left to right by default.
If you mean right to left then set,
POSITION.rotate.angle : 180deg
I don’t seem to see that option through my end how can I add it?
I have tried this already and this is what happens
I see "shrink" and "basis" in your screengrab and the Progress Bar component doesn't have these properties. I suspect that you've selected the wrong component or a container.
Right-click on the progress bar in the Project Browser and Deep Select.
They probably have the Progress Bar in a Flex container, in which case they would have "shrink" and "basis" and wouldn't be able to use "rotate".
Please use the settings below to have the track bar going from right to left:
The transform : scale(-1) in the track property allows to reverse the progress bar.
Adding the second transform: scale(-1) in the valueDisplay allows to ensure the text is not reversed.
