Progress bar text in power table
I managed to display a progress bar in a power table using the following code:
if colName == "Status":
		from javax.swing import JProgressBar
		from java.awt import Color
		bar = JProgressBar(0,100, setPaintedString=Ture)
		bar.background = Color.WHITE
		bar.foreground = Color.BLUE
               bar.setValue(int(value))
		return {'renderer': bar}
i wounder if it is possible to change the font type and size, and if it is possible to change the alignment of the text (put it on the right of the progress bar). Thanks in advance
Hey,
I have also tried to show the value as string. Without the “setStringPainted” it works fine.
But as soon as I add this part, the progress bar disappears…
	if rowIndex == 2 and colIndex == 2:
		bar = JProgressBar(0,500)
		bar.foreground = Color.BLACK
		bar.setValue(80)
		bar.setStringPainted(true)
does anybody know how to fix that?
Thank You (:slight_smile:
you can try to set the stringPainted in the constructor:
bar = JProgressBar(0,500,StringPainted=True)
Change true to True
Thank you jpark, now it works!
Is there a way to change the value from percentage to the value itself?
