Is there a way to make the progress bar value read as a float instead of an integer? I have had no luck so far.
This is in vision. I apologize for any confusion.
Not with the progress bar, but you can use the level indicator instead.
Set it's orientation to left right and the value format to #.0
Adjust colors etc.
It can be done by using the property change event handler to directly set the string property when the progress bar's value property changes.
Example:
# Written for the progress bar's propertyChange event handler
# Any time the progress bar's value changes...
if event.propertyName == 'value':
# Using a respective min/max of 0/1000
# Convert the value to a string that represents a 0.0 to 100.0 percentage
# ...and assign it to the string property
event.source.string = unicode(event.newValue * .1) + '%'
Result:
