Project and Shared scripts unaccessible (Reporting Module)
The reporting module displays a "Data Collection Error" message whenever trying to call scripts from Scripting>Project Library>project or Scripting>Project>shared.
I tried the following combinations:
import shared.myScript
foo()
from shared.myScript import foo
foo()
shared.myScript.foo()
Additional Info:
Using Ignition Designer (Mac)
Ignition 8.0.15
You upgraded from 7.9 or an earlier version? Did you restore your .gwbk directly/run the installer to upgrade, or manually restore your project(s)?
We upgraded from 7.9.9 using the installer. Our reporting needs changed a little so I’m building the new reports from scratch in 8.0. Not sure if it’s related but the script I’m referencing from Shared scripts uses function system.mes.loadMESObject.
I troubleshooted a little more and it seems that the following form does work
The error was caused by incorrect parameters passed to system.mes.loadMESObject() within the script.
