I ran into this today, I’ve setup some audit tables for a couple of my applications. I normally use a custom set of permissions for sql users and didn’t assign anything beyond insert/select for this DB.
Once I assigned it to a project and started opening/closing the project, I got some console spam for each event complaining about not having the “delete” permission.(this is running 7.7.1) Mind, the audit event inserts worked fine.
Intended?
