Hi All,
Is there a way to run automatically a project once the gateway is started?
Stefano
All projects are stored on the gateway. When the gateway has started all project are running also (unless they are disabled in gateway settings).
But… you probably mean Clients???
Yes
I need to open a project automatically on the client.
Only once gateway is started to avoid the message “error contacting gateway”.
In this specific case gateway and client are running on same machine.
If this is a Windows machine, I would suggest looking into Windows Task Scheduler and the Native Client Launcher. You could set up a windows shortcut/batch file that passes the requisite arguments into the NCL to launch the client.
https://docs.inductiveautomation.com/display/DOC79/Native+Client+Launchers
