Project Designer and Client error and unable to open
Suddenly unable to open project designer or lunch Client below is error log .
i have Version: 7.9.8 (b2018053113) ,
simpleorm.utils.SException$Jdbc: Executing SELECT PROJECT_RESOURCES.PROJECT_RESOURCES_ID, PROJECT_RESOURCES.ResourceId, PROJECT_RESOURCES.ProjectId, PROJECT_RESOURCES.Name, PROJECT_RESOURCES.Documentation, PROJECT_RESOURCES.ModuleId, PROJECT_RESOURCES.ModuleVersion, PROJECT_RESOURCES.ResourceType, PROJECT_RESOURCES.SerializationVersion, PROJECT_RESOURCES.Scope, PROJECT_RESOURCES.ParentUUID, PROJECT_RESOURCES.Data, PROJECT_RESOURCES.Protected, PROJECT_RESOURCES.LastEdit, PROJECT_RESOURCES.Deleted, PROJECT_RESOURCES.Published, PROJECT_RESOURCES.Staging, PROJECT_RESOURCES.OEMLocked FROM PROJECT_RESOURCES WHERE (PROJECT_RESOURCES.ProjectId = ? ) AND (PROJECT_RESOURCES.Published = ? ) ORDER BY PROJECT_RESOURCES.LastEdit DESC
at simpleorm.sessionjdbc.SQueryExecute.executeQuery(SQueryExecute.java:63)
at simpleorm.sessionjdbc.SSessionJdbc.queryNoFlush(SSessionJdbc.java:525)
at simpleorm.sessionjdbc.SSessionJdbc.query(SSessionJdbc.java:534)
at com.inductiveautomation.ignition.gateway.project.ProjectManagerImpl.loadProjectResources(ProjectManagerImpl.java:612)
at com.inductiveautomation.ignition.gateway.project.ProjectManagerImpl.loadProject(ProjectManagerImpl.java:599)
at com.inductiveautomation.ignition.gateway.project.ProjectManagerImpl.getProjectsFull(ProjectManagerImpl.java:1572)
at com.inductiveautomation.ignition.gateway.servlets.ProjectListServlet.doGet(ProjectListServlet.java:133)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:518)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
at java.lang.Thread.run(Unknown Source)
Caused by: org.sqlite.SQLiteException: [SQLITE_NOMEM] A malloc() failed (out of memory)
at org.sqlite.core.DB.newSQLException(DB.java:909)
at org.sqlite.core.DB.newSQLException(DB.java:921)
at org.sqlite.core.DB.execute(DB.java:825)
at org.sqlite.jdbc3.JDBC3PreparedStatement.executeQuery(JDBC3PreparedStatement.java:77)
at com.inductiveautomation.ignition.gateway.localdb.DelegatingDataSource$DelegatingConnection$DelegatingPreparedStatement.executeQuery(DelegatingDataSource.java:575)
at simpleorm.sessionjdbc.SQueryExecute.executeQuery(SQueryExecute.java:61)
... 32 common frames omitted
Looks like your gateway is out of memory or something. Try restarting it to get going again. Get the logs and contact support.
Thanks Kevin . it works after restart the Gateway .
Thanks,
