Gateway is on Ignition v8.1.9, Perspective app is v1.0.3-79 running on a Kindle. I’m using the map component for a custom map that’s pulling an image in from S3 for the layers/raster/image/0/source property. The url itself is a pre-signed url generated from an api call triggered by the ‘onstartup’ event. I can navigate around the map for less than 30 seconds before I get kicked out of the project and back to the application select screen.
The map in the demo seems to work fine, as does the map component when the project is accessed via Firefox. Not quite sure how to start digging into this, as the logs aren’t capturing anything…
