I have a new project that I’ve recently deployed and both clients are freezing rather frequently. They are installed on panel pc’s with 8gb of ram and a 6 gen Core I-5. Max client ram is currently set to 1024. Should I increase this to 2 MB? These clients are displaying images from a Cognex camera through the web browser module which is the only component that I could see potentially causing an issue. Occasionally, I get a failed to load error in the console so I’m not sure if that could be causing the entire project to freeze? I’ve placed the error below:
15:34:29.738 [Browser Events Thread] INFO WebBrowser.BrowserComponent - Web browser frame failed to load. Error = ABORTED, URL = file://172.18.217.162/c$/LabelVerifierImages/DM262-5C040809.svg
