Project Inheritance can't be removed
Hello, each new project that I create with Ignition Designer, the Inheritance is active. I verified the Ignition Config -> Projects -> Inheritable value is set to False, and no Parent projects are present. Why the inheritance is active?
Can pls help me pls, thanks.
Thomas
Where are you seeing inheritance active?
