Hello,
I need to call Jython function from Java SDK. Is it possible to access to Project Library from Java SDK in Client or Gateway scope ?
Thank you
Hello,
Thank you
It’s possible, but generally not a good idea to directly call a script library. Better practice would be to create your own script editor (see CodeEditorFactory or ExtensionCodeEditor) to allow end users dynamic scripting in the designer.
In either event, you’ll want to access the ScriptManager from the scope’s local context object. There’s a variety of methods on that class to precompile or directly run arbitrary code.
