Project Library scripts
Maybe this a perspective thing, but I'm trying to call a project script from the script console (also tried a button in a view) and get the error below.
my function call:
project.test.scriptName()
error:
NameError: name 'project' is not defined
How do I call a project script?
If you can't in perspective, where should I put things that will be reused in lots of places?
drop project. its no longer required in Ignition 8.
thank you!
Now I’m getting the same thing, but from a gateway script. I’ve copied the exact script that was running on a tag, to a gateway timer event. I have the correct project set under gateway settings for scripts.
my gateway script:
client = p1.srmCredentials.getClient()
the error:
... line 2, in getInfo NameError: global name 'project' is not defined
The scripts: image
Ah, well my gateway event script was inside of a function. When I took it out of the function and ran it it found the project scripts.
Sorry for the thread revival, but after a search this is the closest match I've found so far.
I'm trying to debug a script. Vision 8.1.35, but was upgraded from 7.9.
I want to call a project script from the script console to test.
Can I not see the wood for the trees here, it has been a long week...
Have you tried:
project.ISEM_PG6.runReportAllSites(...)
Upgrades from v7.x put global scripts under the shared. package, and project scripts under the project. package.
yes, it was at that originally, but then saw this thread and removed it. Let me try it back in because I think I might have had a case sensitivity issue too.
Thanks, a step further, it's now failing at line 132 in ISEM_PG6, but at least it's calling it and telling me where.
Have a good weekend!
