Hello,
I am new to Ignition so thanks in advance for any advice.
At a large mining and milling operation, the client has two separate Ignition servers each running their own project which control different processes. I’ve been tasked with loading each project onto each server. In other words, users logging into either server will be able to launch either project on the server they logged into without being redirected.
The problem I am seeing is that even though each project is completely different, they both have the same default name, ONESCADA. The research I’ve done explicitly recommends against changing the project name. Instead, it is recommended that the title be changed. Does anyone have suggestions of how to get these two ONESCADA projects on the same server?
Thanks again for any help,
Kathryn
Kathryn Price
Electric Power Systems, Inc.
907-223-0556
kprice@epsinc.com
