Using Ignition 7.9.2. Using Java Version 8 Update 151 build 1.8.0_151-b12
I have multiple projects on this gateway, but only one is giving me this issue. I am able to open and edit the project inside my designer. But trying to launch a client, the Java popup opens up, but then nothing happens - no login screen, no project window etc. I also cannot run a Published or Staging view of the project from the designer.
I don’t see anything happening in the gateway logs as I do this. I’ve tried exporting and re-importing the project under a new name. When I tried running the gateway, this was in the logs
INFO | jvm 1 | 2019/09/30 11:03:47 | I [Project ] [15:03:47]: Project [BBRC1] starting up... project-name=BBRC1
INFO | jvm 1 | 2019/09/30 11:03:47 | I [C.BasicExecutionEngine ] [15:03:47]: Modifying an existing execution unit. [Owner=named query cache maintenance, Name=bbrc1] project-name=BBRC1
INFO | jvm 1 | 2019/09/30 11:03:47 | I [s.ProjectRunner ] [15:03:47]: Project started.
INFO | jvm 1 | 2019/09/30 11:04:33 | I [P.InternalDatabase ] [15:04:33]: Creating auto-backup of internal database "config.idb"...
INFO | jvm 1 | 2019/09/30 11:04:36 | I [P.InternalDatabase ] [15:04:36]: Created auto-backup of internal database "config.idb" in 2 seconds
but no project window appeared to log into. There are windows in the Vision project that are designated to open at start.
Any ideas?
