Is this something I need to do to get new roles recognised in order to use them in the project properties?
I created a new dummy role to test with ‘PROJ’ which I can see in the list of roles using alt+space, but when I select it, it shows a cross and it doesn’t apply it…
I’ve tried restarting the gateway fwiw and also using a classic user source as well as an IdP, both have the same issue… however other pre-existing roles DO work??
