Project Properties won't open (Ignition 8.0.6)
We are attempting to upgrade to 8.0.6. The project properties dialog box won’t open no matter which method is used.
getting an error “could not initialize class com.inductiveautomation.perspective.designer.project.properties.perspectivepropspanel”
Do you have the Perspective module installed? Can you post the full details of the error message here, encased in triple quotes?
error
	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
	at java.base/java.lang.Class.newInstance(Unknown Source)
	at com.inductiveautomation.ignition.designer.propertyeditor.PropertyEditorDialog.lazyInit(PropertyEditorDialog.java:137)
	at com.inductiveautomation.ignition.designer.gui.LazyFrame.open(LazyFrame.java:73)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.showProjectPropertyEditor(IgnitionDesigner.java:1168)
	at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$3.actionPerformed(NavTreePanel.java:200)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
	at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)```
Yes, it’s in trial but is running.
Just realized this is missing from the beginning of the error dump.
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class com.inductiveautomation.perspective.designer.project.properties.PerspectivePropsPanel
This showed up in the output console of the Designer…
12:56:46.787 [Browser Events Thread] INFO Perspective.SessionProps - store.Client: Hello API call failed: 'Error: Request failed with status code 500'
It looks like the Perspective module is faulted in some way - can you download a gateway log dump, then try uninstalling and reinstalling just the Perspective module? You can individually download it from the website: https://inductiveautomation.com/downloads/archive/8.0.6
The Perspective module appears to have been corrupted. Reinstalling it resolved the problem. Thank you for the help!
