On the gateway, when I try to edit any projects configuration settings and click ‘Save’ I get an page that
say’s only: Internal Error.
Some settings are changed anyway such as Title or Enabled but other I can not change such as Authentication Profile. What gives?
Could you maybe attach (or email to support) the “wrapper.log” file found in “{InstallDir}\logs”? The type of error you’re describing could be caused by a number of things, but seeing the log would help us track it down, and see if it’s something we could guide you around until we fix it.
Regards,
Wrapper attached.
wrapper.zip (83.6 KB)
What version of Ignition is this?
I couldn’t find anything useful in those logs. Maybe you could call into support and show them this behavior?
