Project to project navigation
Hello Team,
   I am working on a project where I have 10 different projects so how can i navigate from one project to different project.
Thanks,
Kartik I
You've managed to create your post as pre-formatted code so the text does not wrap. Remove the leading spaces from each line and it should look normal. Check the preview before submitting.
You also need to tag your question as either Vision or Perspective as the solution will differ in each case.
thanks @Transistor its in Vision module.
You probably want Retargeting.
https://docs.inductiveautomation.com/display/DOC81/Navigation+-+Retargeting
Thanks @jlandwerlen for the reply it really helped me.
